Clears MLD statistics counters.
| vlan_name | Specifies a VLAN name. |
N/A.
Use this command to manually clear MLD statistics counters.
The following example clears all MLD counters for all VLANs:
clear mld counters
If a VLAN is specified, only the counters on the specific VLAN is cleared.
This command was first available in ExtremeXOS 15.2.
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
